In the summer I had new(replacement) Plastic Cladding fitted by a Specialist Cladding Contractor.
On the exterior there were four Weatherboards. All four were removed and replaced with Plastic Cladding. I will concentrate on the two large boards which were 5.5'x4.5' these were removed and replaced with Plastic Cladding. From the time the Cladding was replaced we have become aware of much external noise but in particular traffic noise.Its back to the drawing board to resolve this problem.
It was a mistake to remove the Weatherboards and replace them with Plastic Cladding but the Contractor did not advise of any negative aspects to this work.
I now realise the Weatherboards had excellent sound reduction qualities and good secondary thermal insulation qualities
From what research I have done it appears that good Sound Insulation depends on having an air gap of 2-4",with 4" being considered the optimum. I have a 3" gap behind the Exterior Plastic Cladding and Interior Plasterboard. If new Weatherboards were fitted this gap would still be available for use.
It looks as though I may be forced to buy and fit new Weatherboards but:
1) Do I have any other options? and,
2) If I do refit Weatherboards should I leave the 3" air gap or use Sound Insulation material in this space?
3) Are there any important points(eg material to be used,etc.) that need to be part of the new spec?
I would appreciate any help and guidance to avoid getting it wrong again.
