Had one of these fitted 2 1/2 years ago. Havent had it serviced and not sure plumber who fitted it had all necessary qualifications, certainly nothing on outside tank filled in etc. So 25 yr Guarantee may be absent
Its started to leak from / around hot water outlet, this is a 3/4 elbow to 22 compression.
I half drained tank and cleaned threads and put on plenty PTFE. Probably not as tight as could be due to fact have to position elbow pointing up.
Still leaks 1 drop every 20 secs. Ive read that these cylinders can leak. can you fix them?, or do you think its more likely to be the fitting, any tips, Ive read something about cylinder unions which allow tightening and keep your elbow bend in place.
Cheers for any help
Cheers for any help
