    Dismiss Notice
Noob sink hosewaste pipe questions
Discussion in 'Plumbing and Central Heating' started by neljan, 19 Feb 2018.
  1. neljan
    neljan
    2 Jun 2014
    28
    Thanks Received:
    London
    Country:
    I want to add a half meter or so plastic pipe to this fitting (so that my washing machine drainage pipe will reach) but I'm confused as to which size pipe and fittings I need to look for.
    [​IMG]
    The actual diameter of the pipe is around 30mm but I can only find fittings for 32mm and the couplings on the 32mm fittings look much bigger than the one already in place.
    The pipe looks the same size as the overflow pipe but a search for overflow pipe dimensions gives me 21.5mm.
    I know I can just get an extension pipe for the washing machine but I'd like to do it properly as the join won't be accessible.
    Thanks for your help!
  2. Sponsored Links
  3. The spigot that you're trying to connect too is not designed for rigid pipework. A waste extension for the washing machine is ok as long as the join in the waste is made properly and the waste pipe runs at high level and drops down to the spigot.
    • Thanks Thanks x 1
  4. Nige F
    Nige F
    28 Jun 2005
    21,154
    Thanks Received:
    1,729
    Country:
    As newboy says. You can get a hose extension kit at any DIY store
    • Thanks Thanks x 1
  5. neljan
    neljan
    2 Jun 2014
    28
    Thanks Received:
    London
    Country:
    Thanks very much.
    Can you recommend any fixings for the waste pipe?
    • Thanks Thanks x 1
  6. Madrab
    Madrab
    4 Oct 2012
    7,931
    Thanks Received:
    2,237
    East Renfrewshire
    Country:
    You want one of these plus a couple of jubilee clips
    [​IMG]
    Just search for a washing machine drain hose connector.
    • Thanks Thanks x 1
  7. DIYnot Local
    3 Sep 2019
    Country:
  8. Sponsored Links
Loading...
Share This Page
