keep getting air in most of the radiators some work some times others dont , the three double ones in front room dont work and have no air in them , its a combi maxi boiler pressure 1.5 bar
If you keep having to bleed them, it might be due to corrosion of the radiators which makes the water go a black soil colour and also produces hydrogen. if so the systems needs draining, or even flushing through to remove blockages then an inhibitor adding to prevent further corrosion.
