This is a bricklayer's accident report, which was printed in the
newsletter of the Australian equivalent of the Workers' Compensation
board. This is a true story... Not DIY disaster related as such, but hilarious none the less
Dear Sir,
I am writing in response to your request for additional information in
Block 3 of the accident report form. I put "poor planning" as the cause
of my accident. You asked for a fuller explanation and I trust the
following details will be sufficient.
I am a bricklayer by trade. On the day of the accident, I was working
alone on the roof of a new six-story building. When I completed my work,
I found that I had some bricks left over which, when weighed later were
found to be slightly in excess of 500lbs.
Rather than carry the bricks down by hand I decided to lower them in a
barrel by using a pulley, which was attached to the side of the building
on the sixth floor. Securing the rope at ground I went up to the roof,
swung the barrel out and loaded the bricks into it. Then I went down and
untied the rope, holding it tightly to ensure a slow descent of the
bricks.
You will note in Block 11 of the accident report form that I weigh
135lbs. Due to my surprise at being jerked off the ground so suddenly, I
lost my presence of mind and forgot to let go of the rope. Needless to
say, I proceeded at a rapid rate up the side of the building.
In the vicinity of the third floor, I met the barrel, which was now
proceeding downward at an equally impressive speed. This explained the
fractured skull, minor abrasions and the broken collar bone, as listed
in section 3 of the accident report form. Slowed only slightly, I
continued my rapid ascent, not stopping until the fingers of my right
hand were two knuckles deep into the pulley. Fortunately by this time I
had regained my presence of mind and was able to hold tightly to the
rope, in spite of beginning to experience pain.
At approximately the same time, however, the barrel of bricks hit the
ground and the bottom fell out of the barrel. Now devoid of the weight
of the bricks, that barrel weighed approximately 50lbs. I refer you
again to my
weight. As you can imagine, I began a rapid descent, down the side of
the building.
In the vicinity of the third floor, I met the barrel coming up. This
accounts for the two fractured ankles, broken tooth and several
lacerations of my legs and lower body.
Here my luck began to change slightly. The encounter with the barrel
seemed to slow me enough to lessen my injuries when I fell into the
pile of bricks and fortunately only three vertebrae were cracked. I am
sorry to report, however,
as I lay there on the pile of bricks, in pain, unable to move, I
again lost my composure and presence of mind and let go of the rope
and I lay there watching the empty barrel begin its journey back down
onto me.
This explains the two broken legs.
I hope this answers your inquiry
Dear Sir,
bricks.
again to my
the building.
onto me.
