Not standard fuses I can just flip?
13 Aug 2025
Lost most of the ground floor lights last night. I have no idea what these are tbh and don't want to just yank them out. Would flipping the main switch on/off reset a fuse?
Thanks all.
No they are fuse wire holders, you've had a fault either over load or short circuit. (Probably not overload as its a lighting circuit)
You need to rectify the fault and replace the wire with the correct size wire, if you dont sort the fault first it my bang as you put it back in.
My own property, seems the type of thing I should get an electrician to deal with, in fact I will modernize, what a pain in the ass.
I would prefer just having normal switches sorted, what a pain, I guess I need a new unit.
Don't know when the Wylex fuse box was discontinued, but likely some 30 or more years ago. The fuse sizes would normally go in descending order from the isolator, so it seems some work has been done to it, you use to be able to buy the switch version,
but the bases also need changing so although only one screw, they are not simply plug in. And no longer made, so would need to get second hand devices, which is not really the way to go.
Lights are likely 6 amp white, but some thing has to have made it rupture, in the old days of tungsten lamps, they could fail with a flash, which was ionisation of the gas in the bulb, and this could cause a fuse to rupture or a trip to open, but LED bulbs used today don't have the same problem, so seems unlikely that would cause it to rupture.
Each fuse has a wider blade as it goes up in size, so a larger fuse will not fit.
Don't know when the Wylex fuse box was discontinued, but likely some 30 or more years ago. The fuse sizes would normally go in descending order from the isolator, so it seems some work has been done to it, you use to be able to buy the switch version, View attachment 426959 but the bases also need changing so although only one screw, they are not simply plug in. And no longer made, so would need to get second hand devices, which is not really the way to go.
I put most of the downstairs lights on the night it went, at the same time. I have never done that before, but I was stressed out due to finding mice droppings and wanting to collect them all and blitz the place.
flipping the big main switch won't reset anything on those mate, they're old-school fuse carriers with wire inside that burns through when there's a fault. you'll need to turn the main switch off first before touching anything, then pull the lighting carrier out to inspect the wire. 9 times out of 10 with lights it's just a blown bulb that popped the 5 amp fuse wire, but definitely make sure the power is isolated at the main switch before you pull it.
