NYY-J or 'Tuff Sheath'
2 Dec 2004
Hi, Im going to be having a new circuit installed for power to an outbuilding which initially will only have lights and sockets but eventually might be used to home batteries and a hybrid inverter.
So Im thinking 10mm2 cable for future proofing initially on a 40A MCB which already exists in the consumer unit.
The run is fairly short, under 10m in total. Most of it can be clipped to an external wall or run in conduit on same walls. However there is a short section of approx 1m which needs to run under a rear pedestrian gate access. I was thinking to use 32mm ducting in this part, which will be run in a small trench then concreted in.
Been researching and I think SWA is overkill for this. I like the look of the Doncaster cables Tuff Sheath cable, but it seems hard to find. I could also go for NYY-J cable.
Is it worth holding out for Tuff Sheath, or is any NYY-J cable going to be good enough for this application?
I'd go SWA if its buried.
Im trying to keep bend radius down because its quite tight near the gate and in through two solid brick walls as well. I could gland and terminate externally into an adaptable box externally then take the inner cores through but then that's an extra earth cable that needs running too at both ends. All seems overly complicated for a 1m run under a pedestrian gate. Anyone looking will see the cable ducting exiting the ground literally at both sides of the gate so its not like it will be a hidden cable.
