O Ring Replacement in Electric Shower
27 Sep 2009
Somerset
I live in a VERY hard water area and took my shower apart to clean the heater element.
I put it all back and its leaking on the inlet and stabilising valve. I suspect the O Rings being moved is not sealing properly so I will get some new ones however do not know the size to get. Are they 15mm? If not can you let me know what size and where to get them from, I assume B&Q is good enough?
3 Dec 2007
Essex
Depends what shower it's from.
Useally about 12mm.
Take the old one with you.
3 Dec 2007
Essex
That one will be bigger than a 12mm don't know exact size of that one so you'll have to measure it.
