oak chopping board
25 Nov 2008
Surrey
Morning all,
Some of you may have seen a thread of mine from a couple of months age where I stripped out the downstairs floor and laid oak boards. The boards are 22mm thick.
I have some offcuts that I’m slowly using up. I’ve a couple of wide offcuts and was going to cut one nice and square, route the edges and use it as a chopping board in the kitchen as my current one is split.
When you buy an oak chopping board from a shop it appears to just be untreated oak. Can I just use the oak as it is without it harboring all sorts of nasties, or will I have to treat it?
Thanks all
wood by its nature has a natural disinfectans effect
you still need to wash clean but do not soak
if your timber is finnished sand the surface clean
glue boards on top off each other at right angles to help prevent cupping and warping with waterproof glue
remember steel or cast iron and wet oak = black marks /weeping on the wood as the tannin in the oak acts with the metal
you can lay wet metal on the oak for a few mins but wipe dry within a few mins
hot pans for example
i would just go for nowt at all and live with the carricter that develops
