    Dismiss Notice
Odd boiler pressure issue
Discussion in 'Plumbing and Central Heating' started by Ali Ahmed, 25 Jan 2021.
  1. Ali Ahmed
    Ali Ahmed
    21 Nov 2017
    52
    Thanks Received:
    Country:
    I have a 2yr old Ideal Logic C35 boiler which is losing pressure 5 to 6 times a day. To diagnose whether it was the boiler or system, I done the following:
    1 At 1am when the boiler hadn't been used for over 2hrs, I put the pressure upto 2 bars.
    2 I isolated the boiler by turning the CH flow and return pipes and cold water pipe.
    3 Switched the boiler off at mains.
    4 Put a bag/bowl aroud the prv and condense pipe to collect ang water.
    In the morning the boiler pressure dropped to zero but absolutely no water from either pipes. A gas safe engineer who was advising me over the phone said its really srrange and there was nothing he could do. I contacted Ideal Logic and they said it was strange that no water is leaking. The advised to book their engineer for a fixed price repair of £295.00 whatever the fault. Before I take the plunge in these hard times, does anyone have any ideas as to what the problem might be?
  2. Sponsored Links
  3. Chris_W
    Chris_W
    26 Sep 2019
    6,190
    Thanks Received:
    1,619
    North
    Country:
    If you isolated the boiler, didn’t use it at all overnight and it dropped, possibly leaking down the condense pipe, best leave it to Ideal for the fpr.
  4. Ali Ahmed
    Ali Ahmed
    21 Nov 2017
    52
    Thanks Received:
    Country:
    I put a bowl around the condense pipe and the was no water leak
  5. Chris_W
    Chris_W
    26 Sep 2019
    6,190
    Thanks Received:
    1,619
    North
    Country:
    Well it’s going somewhere
  6. MeldrewsMate
    MeldrewsMate
    27 Jan 2010
    955
    Thanks Received:
    235
    Buckinghamshire, Darn Sarf
    Country:
    Hmmm. How did you pit up the pressure if the boiler was isolated?
    And what was the boiler temperature when you switched it off? Hot? Cold?
    Did you also isolate the cold mains water inlet to this combi boiler?
    Please remove the ambiguities and post clearly what you did, and in what order.
    • Like Like x 1
  7. Ali Ahmed
    Ali Ahmed
    21 Nov 2017
    52
    Thanks Received:
    Country:
  8. terryplumb
    terryplumb
    8 May 2017
    5,634
    Thanks Received:
    1,146
    Country:
    What exactly did you do to " isolate" the boiler ?
    I suspect you have not isolated the boiler from the flow and return pipework ,and you have a leak on your system.
  9. MeldrewsMate
    MeldrewsMate
    27 Jan 2010
    955
    Thanks Received:
    235
    Country:
    And did anyone use or try to use any hot tap during this test period?
  10. Sponsored Links
  11. MeldrewsMate
    MeldrewsMate
    27 Jan 2010
    955
    Thanks Received:
    235
    Country:
    Suggest you repeat the test tonight...
    1. Start with a cold boiler.
    2. Top-up to 2 bar.
    3. Isolate ONLY the heating flowand return pipework.
    4. Switch off the boiler.
    5. Review in the morning
    • Like Like x 1
  12. Ali Ahmed
    Ali Ahmed
    21 Nov 2017
    52
    Thanks Received:
    Country:
    No, not until 7.30am when I swithed the boiler back on.
  13. Ali Ahmed
    Ali Ahmed
    21 Nov 2017
    52
    Thanks Received:
    Country:
    The gas engineer told me which pipes to turn off. They are coloured so its easy to identify.
  14. terryplumb
    terryplumb
    8 May 2017
    5,634
    Thanks Received:
    1,146
    Country:
    Boiler isolation valves are notorious for not fully closing. You have a leak on the system side.
    Do you have any of your central heating pipes either buried in concrete ,or under flooring anywhere ?
  15. Ali Ahmed
    Ali Ahmed
    21 Nov 2017
    52
    Thanks Received:
    Country:
    Thanks, will do. Message back in the morning.
    • Like Like x 1
  16. Ali Ahmed
    Ali Ahmed
    21 Nov 2017
    52
    Thanks Received:
    Country:
    Yeah, most of the pipework is buried under floor or walls.
  17. terryplumb
    terryplumb
    8 May 2017
    5,634
    Thanks Received:
    1,146
    Country:
    I assumed so.
Loading...
Share This Page
