Yes ,but it's a lot of effort / time / expense ,to no avail . It's obvious from what you have done and advised us ,that one or both valves must be passing.
I've looked at the concrete floor with the imaging camera but cannot find any leaks. The pipes under the floorboards are hard to see with the camera so I guess its taking out the floorboards time.
Checked pipes under floorboards in one room today. Quite a job for a novice like me. Couldn't find any leaks. Got 2 more rooms to go, then the concrete kitchen floor.
I did realise that if I leaving the hot water tap running, then the boiler pressure doesn't drop. The same is the case with the central heating. Does that make a difference or is it still a pipe leak I should be looking for?
