Whilst changing some taps in a groundfloor cloaks, for a client I plugged in my lead light into the nearest double socket which was under a desk in her study. The light worked fine (has a metal clamp and cage on it) by the way. As I went to reposition the light whilst touching the first of the taps I'd changed I got a belt up the left arm and the RCD operated at the CU. Reaction ouch!!.............. and Christ how did that happen......
Thinking my light was dodgy I put in the van to check later.
Client was worried about me............nice girl. As I was about to leave we spoke about it again and she asked if I'd check the double. I plugged in my M/dale and only the L/H LED lit up indicating reversed L/N. The connections were correct in the socket in question, so I then checked back to a nearby socket which it was spurred from and all connections were OK there too. It turned out the cable between the two sockets was faulty and I duly replaced it and tested it...sorted.
She'd had a telephone base station plugged into it but couldn't understand why the batteries kept go flat instead of being recharged.
My question is .............how did the shock come about?
Was it due to a break in the N and the CPC temporarily becoming a N with me touching the tap which was bonded which made the RCD open?
If the N was broken how did my light work?
Puzzled.
Cheers
Harry.
Puzzled.
Cheers
Harry.
