Off Set and Swan neck connectors
24 Jun 2009
West Midlands
I am fitting a new toilet and want to move it slightly to the right of where the soil pipe is in the floor.
The soil pipe is in concrete and at this point do not want to start digging that up.
Its a close coupled WC with the outlet being horizontal, can I put an offset in the top of the 110mm in the floor, and then drop the swan neck straight onto this if I remove the fins? This would mean of course that the offset is above ground level.
Or would my best bet be to buy a 90 degree flexible connection?
Cheers
Adam
Probably easier using a flexi pan con rather than and offset and swan neck together. It's not great using two together tbh.
