Off the shelf internal door frame with threshold?
30 Mar 2012
Monmouthshire
I'm converting a car port which used to house the front door (with side light) so there will now need to be a standard 30" internal door there, but there also needs be a step down in to the new room as levels differ.
Is a standard 32" door frame that includes a (preferably hardwood) threshold available off the shelf?
Obvs, I'll need to make the aperture smaller for the new door frame: I'll probably tie in some Celcon blocks as that wall is now internal? What tolerance for packs is usually added to a 32" frame when doing the blockwork?
Any pointers very much appreciated.
Thank you
Dain
why don't you just fit a 32" door?
Internal door linings ("frames") do not include the threshold, which is sold and fitted separately.
Show us a pic of your other internal doors.
Are you suggesting it's usually a good idea to use an opportunity to install a slightly wider door?
The other internal doors are all 30" Georgian 6 panel pine in 32" linings
The aperture (without the old front door) is now 48"
I thought, from reading your earlier post, that you had a gap to fit a 32" door.
48" would be a bit on the big side, unless you want to add a side light.
No, I hought I'd do the job properly: don't contribute unles you have a valid contribution, whch clearly you don't.
Just as you wish.
I read this
And thought you meant you had a 32" gap.
Sorry you feel offended.
