As I said in my previous topic, my old Boulter 90/130 boiler is using a crazy amount of oil, around 1000L per month.
I inherited this old boiler when I bought the house last year and the previous owner fancied himself as a bit of a diy’er.
I believe the burner unit fitted to this boiler is not the original one and it was probably fitted by the previous owner.
And of course not set up and adjusted properly.
When I disassembled the burner last may I found the baffle (air flow thingy to make the air flow swirl) fitted incorrectly and its adjustment screw missing.
It was also coated with a thick layer of black soot, and when in operation it produces a very orange flame.
I don’t know if oil burners are supposed to produce an orange flame or if it should be blue?
If someone could let me know?
The burner is a:
RBL G7x
Type 458 T55
Cod 3745855
Mfd date 1995
Jet size 2.45- 5.8 kg/h
Rated at 29 - 69 kw
Does anyone have or know where I can get a service manual for this burner and some spare parts to service it with?
I have also had a thought that it could be delivering too much oil for the air flow it has and that it could be adjusted or a smaller nozzle fitted or perhaps both?
this might help with the excessive oil consumption?
Any advice gratefully received.
Andy
The burner is a:
RBL G7x
Type 458 T55
Cod 3745855
Mfd date 1995
Rated at 29 - 69 kw
Andy
