Just regarding the solenoid coil on top of the pump, its only really testable when it has failed - but they do fail fairly often and I always have them in stock. Around £25 for a Danfoss one.
John
John
Sounds a bit like Schrodinger's cat I think I know what you mean though.its only really testable when it has failed
At the point of lockout, pull out the burner and look at the nozzle and into the combustion chamber for signs of oil. If oil is there, change the EBI ignition unit. Stix.
It is possible to check these visually, disconnecting the pump coil, and start and stop the burner a few times without letting it go to lockout. If it is weak, then after the 3rd or 4th time, you will see the spark diminish.Might not need to change 1 for ages, then 2 or 3 three at once (like waiting for a bus). Just when they are goosed. Most show no visible sign of fault but can still give intermittent lockout. Stix.
No such luck It ran for 7+ hours after I had cleaned the inline filter, but then it locked out again. It's now back to running for an hour or less after resets.It's now been running for 3.5hrs without locking out though so, with any luck...
Boxersoft";p="1861107 said:It's now been running for 3.5hrs without locking out though so, with any luck...
Try fitting a new motor capacitor I am sure this will cure the fault.
spraggo
