old boiler
23 Mar 2006
Cambridgeshire
I have a problem with a glow worm space saver 38. When it is turned on it fires up runs for 2 to 3 minuets and then turns off. The pump looks like it is going and have 3 rads downstairs. Problem started when i bled one rad.
Water runs from 2 rads but not the one I bled
the tank is 3/4 full and can hear it fill when i open the other two rads, third is still dry, is it possible rad is blocked stoping the flow of water
brianfrost said:
don't know welder not plumber, good with big hammers,can you help
True. Big hammers solve any problems. I myself have resorted to big hammers in times of desperation. At all other times skillfully prescise.
not much help used hammer, can any help,blocked coold water feed, need to no how to clesr it, geting desparet wife on my back :cry:
You could try tapping it, blowing it out with compressed air can or backfilling it with a hosepipe between the ball valve and stuck down the vent. The reality is though you will need to cut out the section and replace it....don't forget to syphon the water out of the header tank first though.
how would i find the block section to cut it out,and if i was to backfill it would that be from a rad, the block looks like it is between the pump and tank
