Just redecorated the bedroom which also included a new light switch plate. When I came to put on the new switch plate, it became obvious that it wouldn't fit the existing box as the width between the switch plate fitting screws are too wide.
The existing box is a solid metal (looks like steel) and is embedded into a solid plastered wall. I am guess it may be an original fitting from when the house was built (1930's).
I don't particularly want to extract the box. Is there any other option that allow modern standard switch plates to fit older boxes? Or does anywhere stock modern style (white plastic) switch plates that have narrower width between the mounting screws?
Thanks in advance,
Mike
Thanks in advance,
Mike
