- Joined
- 27 Feb 2005
- Messages
- 93
- Reaction score
- 0
- Country
My mate’s washing machine has recently started failing to fully discharge its waste. He lives on the top (7th) floor of a high rise and has used the machine successfully here for about 20 years or so. Currently on removing the load at the end of the cycle about an inch of water is still in the drum. Furthermore the amount of water starts to increase over the next few hours, eventually resulting in an overflow from the machine.
I suspected some sort of problem with back-siphonage so took a look at the installation. Firstly, the waste hose is connected to the vertical waste pipework about 300mm or so above the top of the machine by one of those crappy self-cutting connectors. Secondly, there is no trap of any kind so the top end of the pipework is capped presumably to prevent smells. Thirdly, the other end of this pipe connects to the main building waste via a concrete boss – presumably this area was designed for a WC. Lastly, the gauge of pipe is 11/4 inch.
The washing machine instructions state that the waste will be expelled at up to 35 litres /minute. What surprises me is how the machine has provided such good service given this set up.
I would be interested to hear if anyone has a view on the best way to remedy the current set-up so a conventional 40mm WM stand pipe can be used. Thanks in advance for any help.
