Before I call an electrician, I want to get some idea about the cause of my problem.
In February my mother bought a pair of light fittings, both the same type, transformer mounted in the rose/hub and 5 arms coming out with 12v pin leg type bulbs. One of the units has been fine, but the other has burnt out on 2 occasions. I replaced it the first time and it was ok until a bulb blew, then the unit blew shortly after (same as the 1st time).
I have not put the new replacement up yet, as I am convinced it will not last very long.
The wiring and fuse box are as old as the house (1973), and I have convinced my mother she needs a new consumer distribution board installed. will this prevent the same fault happening or is it likely to be a wiring or earthing issue.
