I wonder if somebody could help as I have little experience of this sort of thing.
The old bell was rusted up and I decided to buy the Odyssey siren/strobe unit.
I'm not bothering with tamper so I'm using 4 core cable
The Omnicron 7000 has
- Bell
+ Bell
+ Strobe
- Strobe
+ Set
The bellbox has
A (12V) Permanent Positive Supply
B (Bell) Negative Applied Output to Activate Siren
C (TAMP) Negative Removed on Tamper Input
D (0V) Permanent Negative Supply
S (STRB) Negative Applied Output to Activate Strobe
I've so far switched the JCP1 battery jumper on and the LEDs come on OK and I can get the siren to sound if connected directly to the panel battery. I have took advice and connected the + Bell connection from the panel to the A (12V) and the Bell - to the B (Bell). I have also connected B directly to S in the bell box. This was suggested as I was originally going to use 2 core. To cut a long story short, it doesn't work. I would therefore like to do this properly using all 4 wires and I assume I need to again switch JCP1 (Battery) back on in the bell box.
Any advice would be appreciated.
- Bell
+ Bell
+ Strobe
- Strobe
+ Set
The bellbox has
