Our oven extractor has failed, it would appear the motor has burnt out!
I have purchased an exact identical model to replace it (Prima 60cm PRCH020), however I note the installation instructions state ".... a suitably dimensioned omnipolar switch with 3mm minimum opening between contacts must be fitted between the appliance and the electricity supply...".
I have no idea who installed the failed extractor as it came with the house, but it was simply connected to the 32A "sockets" circuit using a junction box housed within the "chimney" of the extractor.
The extractor doesn't have an earth wire in the cable, just live and neutral.
I was considering replacing the junction box with a fused switch socket, but they are described as double pole, not omnipolar. However, if there's no earth wire, is double pole the same as omnipolar?
I assume an omnipolar switch (similar to one used for bathroom extractors) doesn't include a fuse, so wouldn't a fused switch socket actually be better?
What I thought would be a straight forward replacement seems to have turned into something a little more complicated.
I would appreciate your thoughts.
