Hi, I've got a problem with a radiator in the bedroom - it is stone cold, and the pipes leading to it and out of it are stone cold.
It is an old conventional open system and all the other radiators are working fine - including the other one in the same bedroom (the bedroom has two windows and a small radiator under each on the same wall). They are just standard on/off values and there is no thermostat.
I decided to drain the whole system, partly because of the issue with this radiator and partly because the system had become noisy and the radiators weren't getting as hot as they used to.
The cold radiator drained fine (which in my layman's world means the out pipe isn't blocked), and once I had flushed the system a few times and refilled with water and Sentinel X400 I bled the cold radiator and it filled back up with water (again suggesting to me there is no blockage on the in pipe).
After bleeding all the radiators I turned the system back on and all the radiators got really hot - much hotter than before the drain, and as a plus there was no pipe noise. However this cold radiator, despite filling up with water, remains stone cold, as do the pipes in and out of it.
I tried turning the pump up to max (level 3) just in case that made a difference, but it's still cold.
I don't think it is a balancing issue as all the other radiators are equally hot when all fully open. Also wouldn't you expect it to be at least slightly warm rather than completely cold?
I'm going to keep the X400 in for a couple of weeks before draining again and refilling with X100 and X200, but I don't really want to do this before I've fixed the cold radiator.
Has anyone got any ideas of what to try next? I don't really want to go to the expense of getting a plumber (I plan on replacing the whole system sooner or later) and although I'm a complete plumbing novice I'm not adverse to a bit of DIY with the right instruction...
