Sounds to me that this post is degenerating into a load of bo***cks, with some trying to score points with ridiculous equations that mean jack sh*t in the real world![]()
what equations?
now im really getting confused
again
Yes. I got that stuck in my head until someom=ne poointed out that you're measuring it relative to atmosphere so you're getting
1015
1021
of what you should, which is 99.4% of it!
You could always freeze your meter to squash more in!
can you explain that more clearly?
so far I imagine, from situations ive seen, where due to inadequately sized supply pipework there has been an inlet pressure as low as 13 mbar,
yet due to the construction of meters they measure volume.
so 1 cu ft of gas is the same volume at 20 mbar as it is at 10 mbar.
reduce the contained pressure to atmospheric pressure then the 20mb has twice the volume as the 10mb.
i would postulate that the calorific value of the 20mb is twice that of the 10mb.
ChrisR said:Remember things like cookers and fires may have no appliance regulator at all, so they would all need changing..
Good grief you must be nearly as thick as Bambi! He's talking rubbish as usual!WDIK said:wow that was the lousiest explaimantion ive read for a while![]()
Iv'e often thought that one of simond's accumulators could be very handy where low pressure is a problem.
Perhaps something for the inventors to make their fortune with.
Yes.so for the mano to read 20mb gas, that means @ zero the gas would be @ absolute pressure of an equal pressure of 1 atmosphere,
so to read 20mb it is 20mb + 1 atmosphere.
but then is that usable gas?
I can't tell if you're joking or not, but emptying a copper pipe of gas, or air, or everything (i.e. creating a vacuum inside it) would not result in the pipe collapsing.the gas moving is the only gas being used, the gas at atmospheric pressure is the gas that would occupy the pipe wether it be methane or air or any other gasious medium to prevent the pipe from collasping under the weight of atmospheric pressure![]()
DOn't need to mate, this is kindergarten stuffWDIK said:read it again Chris
But I need to rub it in so you feel annoyedI'll ignore the slur
Nonsense!the atmospheric element of the pressure is irrelevant and is only there because otherwise the pipe would colapse.
Given the increasing demands for higher gas volumes why are we still working with the relatively low mb operating pressure which was specified decades ago when demands were less.
Why not legislate for an increase in supply pressure and utilise point of use regulation (as regulators are cheap as chips) instead and negate the need to rip out miles of copper every time a new boiler is fitted?
MW
Because miles of copper is never ripped out every time a boiler is fitted, a new boiler is fitted new for old usually & the gas supply rarely changes, the rest of this post and the fools pontificating over it are the same as your theory..........Ridiculous..![]()
SimonD said:You could make a booster that uses mains water pressure in an accumulator vessel to boost the gas pressure. It could act as a buffer for higher power instantaneous water heaters in domestic use.
