I have existing lighting in my garage that has only one switch ( 1 way ) that operates 2 florescent lights, I would like to be able to switch them on from the other end of the garage, can you please help
As said needs three cables and earth between switches. Both switches connected like for like so if brown used with com on one switch then brown also com with other switch.
The original switch wires are also moved so an original switch with Com and L1 used will be replaced using L1 and L2.
Important point is com will only have one wire in it and must be same wire with both switches unless using intermediate switches follow that and can't really get it wrong.
