HI all
My brother and his young family moved in to their first home last week and it has been a complete mare!
Everything from the front door multi point lock jamming, total re skim needed upstairs after removing 4 layers of wall paper, to the heating problem.
I am trying to help out here as funds are exhausted now and the kids need some warmth.
I will try and explain the issue and what i have tried so far to get the 3 rads down stairs to work.
2 of these are on the same run which drops down from the ceiling in the living room and the third is on a separate drop from the ceiling in the hall way.
I think the pump is on the return and attached to the round chamber in the picture which also has the feed and vent going in to it. I assume this is just a common connection point as i have not seen one before?
I think it's the return as it is cooler than the flow although don't think it really matters as it has obviously worked before.
If i run the heating for an hour then the flow pipework that i can see ( i have some access under floors upstairs) is damn hot but the return appears almost cold so i am guessing a blockage judging by some of the crud i drained in to the bath?
I have tried blanking off the vent and using mains pressure connected to the feed pipe to flush through with the y valve open. We did manage to get loads of crud out but rads still seem cold.
Am i missing something here with my flushing technique? What is the round chamber with the feed / vent and flow and return on?
Any advice would be great as i only have tomorrow left to help before i am back on shift.
