S
swidders
Never mind everyone seems to be talking 5hit there at the moment![]()
Indeed I am. Where is it all going
[The answer to that questions to be found in the combustion chamber at the moment![]()
ii) We've noticed that if we run the hot tap full (for a bath) the water isn't very hot, but if we run it more slowly it is scaldingly hot and we need to add plenty of cold (which is what we are used to). Should the tempreture of the DHW vary so much with flow rate? I had assumed that as the boiler has been told what temp to make the DHW that it would just deliver less flow to meet this temp? i.e. that if I put the hot tap on full the boiler would think "well I can't deliver DHW at the temp I have been told to at the maximum flow rate so I will deliver it to temp but at reduced flow rate". It's not a problem I guess but I just wondered if it's normal or if it can be changed?
