Order of installation of mortice fence posts and rails
22 Aug 2010
London
Hi all,
Busy plannign to install some picket style fencing in the front of my property and curious as to the order/method of installing mortice posts with rails.
Do you set the posts the correct distance apart and are the rails flexible enough to bend/force into the posts or do you set the end posts and then with the rail and next post set that one and so on.
I'd imagine it is the latter, but a little baffled as to how long it would take having to only set one post at a time and waiting for that to set.
Any guidance would be appreciated.
Regards
Kyle
I don't know the answer to this question for certain, but I agree that logic dictates it is to set the second post with the rails in place, as bending a rail sounds like a bad idea.
I would also suggest that as long as you only hang the rails and support the posts whilst your concrete sets, then you can just do the run as fast as you can construct it.
I wouldn't think you would have to wait for them all to set first before moving to the next post.
I've seen plenty of professionals do a whole run in a day, then come back a day or so later and fix the fencing to the rails in another day.
I second what's just been said. You can use temporary props to hold the posts vertical while the concrete goes off.
