Merry Christmas!
Having spent a huge amount of time and effort sanding back the floor (old pine boards) I applied 2 coats of OSMO hardwax oil stain (Antique Oak), taking care to leave each section 20 mins before rubbing off with a cloth in the direction of the grain..
It was worth the effort, the floor looked amazing.. dark (almost walnut) and consistent across the entire surface (big room of 40m2)..
A week later I then went to apply the Polyx Oil top coat, which I did with a white scotch pad using a numatic floor polisher..
Having spent so much time on the first part of this job, I was keen to get it finished and started this work late in the day.. predictably I ran out of time and ended up with several areas that I had missed which had swirl marks from where the oil hadn't been thoroughly worked in/ wiped off.
When I came back to it, these were obvious (right in the spot where the light bounces off the floor). reading around, the only solution seemed to be to sand back lightly and then re-apply with Polyx.
Using the floor polisher again, I tried several different pads, but only the Black pad was up to the job.. the trouble was that in addition to removing the excess Polyx, it also lightened the floor (taking the stain up).. leaving me with a very patchy floor.
I thought that I would just be able to re-stain those areas with the hardwax oil.. but depressingly I am have found that the stain doesn't seem to take
Presumably this is because the polyx oil is doing its job and has impregnated the wood..
What are my options? Am I going to have to sand the whole thing back to bare wood and start from scratch? or does anyone have any other ideas?
