    Dismiss Notice
Oso unvented cylinder mystery
Discussion in 'Plumbing and Central Heating' started by lostinthelight, 25 Mar 2019.
  1. lostinthelight
    lostinthelight
    11 Feb 2016
    3,165
    Thanks Received:
    610
    monmouthshire
    Country:
  2. Sponsored Links
  3. JohnD
    JohnD
    15 Nov 2005
    74,272
    Thanks Received:
    4,290
    Crossgates, Europe
    Country:
    Cook Islands
    I didn't understand that.
    it looks like your vid showed, after an initial delay when first powered up, that the iBoost fed a small amount of power to the heater, regulated presumably by the solar available; and then, when you pressed the timed boost, it seemed to feed power for the limited period.
    Have I missed something?
  4. lostinthelight
    lostinthelight
    11 Feb 2016
    3,165
    Thanks Received:
    610
    monmouthshire
    Country:
    I dont believe so, fist off solar via the switch was supplying power then when manual boost is activated solar is replaced by power is taken from the mains which if the panels are generating, are still supplementing the supply
  5. JohnD
    JohnD
    15 Nov 2005
    74,272
    Thanks Received:
    4,290
    Crossgates, Europe
    Country:
    Cook Islands
    I don't see anything wrong with that.
    In the second state, is it 230v (or thereabouts) AC?
  6. lostinthelight
    lostinthelight
    11 Feb 2016
    3,165
    Thanks Received:
    610
    monmouthshire
    Country:
    Yes probably because the fancy circuitry is bypassed, its just the DC stage thats firing the boiler, thats if you believe its capable of supplying Dc to the IH
  7. picasso
    picasso
    8 Apr 2008
    10,632
    Thanks Received:
    2,669
    Essex
    Country:
    Sorry haven't read the whole thread but try changing the electronic cylinder stat for a "mechanical" stat, I reckon the stat is suffering from the inductance on the 230vac immersion cable.
  8. JohnD
    JohnD
    15 Nov 2005
    74,272
    Thanks Received:
    4,290
    Crossgates, Europe
    Country:
    Cook Islands
    Might also be worth changing the flex for shielded, heatproof cable.
    I don't know if there is a supplier of small quantities of screening mesh.
    I have a Steinel tester that identifies AC or DC. No doubt there's a cheap way of checking it or damping the switch-on pulse.
  9. Sponsored Links
  10. lostinthelight
    lostinthelight
    11 Feb 2016
    3,165
    Thanks Received:
    610
    monmouthshire
    Country:
    FWIW some time ago I’d actually pulled the thermostat and its probes well away from the tank and the problem still existed, how far do you think the field inductance would cover?
  11. picasso
    picasso
    8 Apr 2008
    10,632
    Thanks Received:
    2,669
    Essex
    Country:
    Are the cables for the stat and immersion heater run along side each other ?
  12. lostinthelight
    lostinthelight
    11 Feb 2016
    3,165
    Thanks Received:
    610
    monmouthshire
    Country:
    They come from different sides of the tank but the thermostat probe would be very close to the IH wire when its in its pocket . When I moved thermostat to conduct the test it would at least half a meter away
  13. picasso
    picasso
    8 Apr 2008
    10,632
    Thanks Received:
    2,669
    Essex
    Country:
    • Thanks Thanks x 1
  14. lostinthelight
    lostinthelight
    11 Feb 2016
    3,165
    Thanks Received:
    610
    monmouthshire
    Country:
    Thanks I’ll look into it but reluctant to change yet as its still under guarantee..I must say Oso have been less than helpful
  15. lostinthelight
    lostinthelight
    11 Feb 2016
    3,165
    Thanks Received:
    610
    monmouthshire
    Country:
    Thanks for that, have a look at my post and could you please tell me if your controls are the same and how far from the cyl is the iboost.Oh, is it an iboost or iboost+
  16. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
