Out Building 30m2 floor area internal or external?
Not as funny as you think.
That's because building regs are totally separate and the area relates to fire and thermal efficiency and structure etc which all come under building regs. And the internal floor area is more relevant there.
If you breach the height it's planning, if you breach the allowed area (half the area surrounding the original house) it's also planning, both of those are the external sizes and relate to the appearance and impact on others using the surrounding space.
Well explained..i didnt didn't actually find it funny it was more a figure of speech but thank you for the clarification, makes perfect sense.
Yeah i knew what you meant! I meant it in the same way,i should have said it's not as strange as you think!:)
Its a Building Control issue - but yes the guidelines are the same across England I'm sure.
England yes. Scotland, Wales and Northern Ireland each have their own but I don't know how the actual Approved Documents differ from England's.
silly question...
"It's measured between the internal faces of the external walls."
In a timber frame shed which is just studwork and cladding, what counts as the external wall? the back of the cladding? or the internal face of the studwork?
silly question...
The latter. ...and if you get pulled up on it you just board over the inside, voila!
