Outdoor Light
Discussion in 'Electrics UK' started by swaring, 10 Jan 2020.
  1. swaring
    swaring
    11 Nov 2007
    210
    Thanks Received:
    West Midlands
    Country:
    Hi there,
    I wonder if anyone could help. I have just replaced an outdoor light with an Up & Down Light, on the right hand side of the front door. Now the missis has said another light the other side of the front door would look good (she's always right). Now the light switch is right behind where I want this second light to go. Could i drill a hole through the brick and feed some T&E cable direct to the switch as opposed to spurring it from the other light? (Way easier as I don't want any wires showing) Just wondered if it could be done this way?
    Any help much appreciated!
  2. Sponsored Links
  3. SUNRAY
    SUNRAY
    28 Jul 2009
    5,854
    Thanks Received:
    451
    Kent
    Country:
    That all depends...
    Have you had a look behind the switch yet? turn the power off before you unscrew it, a picture of the wiring would be good.
    • Thanks Thanks x 1
  4. swaring
    swaring
    11 Nov 2007
    210
    Thanks Received:
    West Midlands
    Country:
    Ill do it tomorrow thank you for the speedy reply.
  5. winston1
    winston1
    11 Jan 2010
    7,329
    Thanks Received:
    571
    London
    Country:
    Why do you want to light up the sky? You should have used a downlighter only.
  6. ETAF
    ETAF
    24 Apr 2008
    1,237
    Thanks Received:
    213
    UK, Wittering, West Sussex
    Country:
    The switch may not contain a neutral - where is the junction for Live /Neutral /Switched Live /Earth
    • Thanks Thanks x 1
  7. Sponsored Links
  8. swaring
    swaring
    11 Nov 2007
    210
    Thanks Received:
    West Midlands
    Country:
    The house looks nice lit up as it’s very dark where we live (no street lamps)
  9. swaring
    swaring
    11 Nov 2007
    210
    Thanks Received:
    West Midlands
    Country:
    oh that’s great so if the switch contains a neutral, live and earth I’m good to go?
  10. sparkwright
    sparkwright
    20 Aug 2009
    8,959
    Thanks Received:
    1,128
    Dorset
    Country:
    Yes, but you have to be certain what you believe to be a neutral REALLY IS a neutral.
    • Thanks Thanks x 1
  11. terryplumb
    terryplumb
    8 May 2017
    6,351
    Thanks Received:
    1,334
    Country:
    Yes you would .
  12. ETAF
    ETAF
    24 Apr 2008
    1,237
    Thanks Received:
    213
    Country:
    Usually a switch will have twin&E Red/Black/Bare or if new , Brown/Blue/Bare
    The bare is the earth and usually sleeved in Green/yellow striped
    BUT the other two are LIVE only and NOT neutral
    For example the RED or Brown is live from the Supply and then When switched uses the Black/Blue to take the Live to the Light
    the Black/Blue should have a red/Brown sleeve on to donate that it is actually a live wire
    A photo may help , if different
    • Thanks Thanks x 1
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
