I've got an electrician coming round in the next few days I wondered if I could get some input from here so I have an idea of what is possible etc.
Basically, I'm having my patio redone and it's already had 2 skips taken out in order to drop the level down 150mm below my DPC. The build has asked if I want any ducts running for any electrics. The only thing I can think of is I might want a few outdoor lights around the edge.
As you can see from the photos I have two wall mounted outside lights currently. The indoor switch is roughly behind the one on the left. Would it be possible to make use of this switch (possibly turn it into a double switch) and use the lighting feed to run out into the garden?
You'll also notice that I have an outdoor socket too so I don't know if this will influence your comments.
All of this was fitted by the previous owners by the way.
Thanks for any help/suggestions you can give me.
