Hi
I've just discovered the outdoor tap (pic 1 - link below) has been leaking for sometime. Im happy to have a go at replacing the washer, assuming thats what it is, but there's no obviously way to shut off the water supply. Pic 2 shows the pipe immediately inside - can I shut off the water supply by simply turning the screw in the picture or is that a bad idea? If the latter, where am i likely to be able to turn the water supply off?
And secondly, any tips on fixing the tap!?
Thanks in advance.
Adam (leaking tap novice)
//www.diynot.com/network/DINGO1303/albums/
Thanks in advance.
