Outdoor WiFi Extender
10 Dec 2008
Jersey Marine
I have EE Broadband Gigabit Fibre.
It comes with their Smart Hub 6 Plus
I connect to some SMART outdoor sockets - worked OK for a year, but they now can't connect to the network. I have an EE WiFi extender in the nearest room of the house.
Connectivity works if I bring Smart sockets inside, but no longer works where they need to be, although they are at the end of the garden and the signal is going through a wall.
Thinking of using an outdoor WiFi extender, anybody any experience with these (2.4GHz only required)
Or easier, can you still get an extender to use indoors, but has an external antenna?
Be a bit of a pain to run ethernet through the house, do any of these extenders work like EE ones --- i.e pick up a signal by WiFi and repeat it .,... they are not cable connected - but will run ethernet if need be.
Cable is by far so much better. Just be kind to your neighbours and use cable. FYI 2.4GHz wifi only has 3 clear channels out of 11 or 13.
The more WiFi you use the more your neighbours will want to use more repeaters, extenders just work normally. Then you will need more to compensate for their increases in using extenders.
I use a mesh system , one unit in loft at rear of property , one in window of annex at bottom of garden ( about 35m) and get Wi-Fi everywhere .
