outlook
18 May 2004
depends where i get sent
i was gonna tag this on chris r s but decided not to confuse the issue
i can recive e mail but not send
i dont want to post a load of meaningless info but
if you need any no probs
tia
Kev, you need to post your incoming and outgoing server settings (not passwords tho ;-) ), also any error message you get when you try to send. Have you been able to send email previously? (i.e. has something changed?)
your name............kev
e mail [email protected]
incoming mail server (pop3):......pop.ntlworld.com
outgoing mail server (smtp).......smtp.ntlworld.com
username................................kev.plumb
my outgoing server smtp requires authentication .is checked
log onto incoming mail server before sending mail ........is checked
connect using LAN...... is checked
incoming server port 110
outgoing server port 25
ssl not checked on either port
error message
task'pop.ntlworld-sendin reported error(0x800ccc67):'the server responded:? 1 aamtaout02-winn.ispmail.ntl.com connection refused from[75.143.174.41]'
also get error 0x800c8105 unknown error
hope this makes sense :?
only thing different is i am in the states :wink:
You've got a dumb american ISP, congrats. Then again, in this case it's good for you.
Enable SSL for both incoming and outgoing, port 995 for POP3 and 465 for SMTP.
ok done that now i get
error 0x800ccc67the server responded
1aamtaut04winn.isp.mail.ntl.com connection refused from 75.143.147.41
edit the ports have gone back to 110 and 25 :?
Ah, that's a pain, they refuse connection unless you're on NTL (well, Virgin these days).
Charter should provide an SMTP server, you should be able to use that (with your Virgin email address but Charter login details).
Kev, C&W/Ntl/Virgin or whatever they are calling themselves this week have been F******g about with their servers for weeks now and have caused so many problems its unreal!
did you update your email box when told to? (last 2 months) as everyone has had to update their settings if using outlook (luckily i don't!!)
go to virginmedia site front page and follow the link on there.
hope this helps
kev
Changing his settings isn't really going to help when the server refuses his connection before any of them can be used!
