- Joined
- 18 Jun 2004
- Messages
- 82
- Reaction score
- 0
- Country
Sorry if this has been covered before ....
I'm renovating a largish shed (actuallya single stabling unit) of about 14 x 11 feet and want to put electricity in there from the house.
My kitchen has a 4-way CU (Wylex) with wired fuses, one of which (I think) isn't connected to anything. My plan so far is this:
Replace that wire fuse with a Wylex plug-in type MCB (20A? 32A?)
Take that cct via T+E cable to a RCD/switch box on the inside of the kitchen's outside wall
Armoured cable from there (through the wall) to the shed (only a few feet, and not in a place where anyone will dig, but hard to bury the cable 750mm due to drains - can I get away with less?)
terminate the armoured cable in the shed at a garage-type CU (2xMCB plus 1 RCD) and run 2 double sockets from the 16A MCB (T+E in plastic trunking) and neon lights from 6A MCB (T+E surface-clipped to beams).
1 - Have I made any serious errors?
2. Should I change the kitchen CU to a more modern all-MCB/RCD unit? If so, do I need the other switch box in the kitchen? What type?
3. How do I get the armoured cable through the wall and down (it only bends around quite a large radius, obviously)
4. Do I need a sw/fuse or some such in the shed, as well as the garage CU?
Any help much appreciated, sorry I'm a bit of a novice at all this
