Currently replacing my outside pir lantern, which was wired with 3c+e. One permanent live which I assume controlled the sensor and a switched live which was an override to have the light on permanent.
The light I am putting up only has L, N and earth terminals in the connector block inside so my question is how would I wire the light to function the same as the old light? (controlled by the pir unless switched at the wall to be on permanent)
Thanks in advance
Thanks in advance
