Got some lights to put up outside, got two bulkhead lighting fittings wired via a stand alone dusk/dawn switch. Need to fit them to the outside of the garage.
The wiring will be run from a fused spur in the garage internally then out into the backs of each fitting.
The instructions in the units say that 1.5mm 3 core flex should be used, but i thought that the wiring regs stated that flex should not be used on fixed installations.
Should i use flex or twin & earth??
