Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Hi DESL
The lights terminate with a 13amp plug which is plugged into an RCD in a 13amp socket. This part seems to be fine, as other items plugged into the RCD work OK. How will I check for voltage with power off?
