Hi
Put up a standard, stainless stell sensor outside the front door today. Wiring was easy as it replaced an old one. Before I fitted the light I had to remove the nuts from the pretty front cover and two metal washers fell out.
So far so good you will say. However, when I stuck it on the fall and tried to get the same washers to go on the protruding bolt... they would not. Tried and tried manipulating but they would not go-either of em.
Had to tighten the nuts to close off as it started raining but am worried that the stainless steel cover will get damaged due to the pressure of the nuts.
Has anyone come across this?
Feel a bit flabberghasted actually?
Cheers
c
Cheers
c
