Hi guys and advice is greatly apprecited. Im thinking of installing an oustide light just outside my front door with a switch just inside the hall.
-My question is can I take the power from behind a wall socket, then chase the wires through the wall which will lead to a switch then to the light outside?
- Im not sure if the socket is a ring circuit or a radial circuit. Behind the back of the socket theres just one set of wires (2.5mm) live neutral and earth. The leads me to think its the end socket on a radial circuit. Would adding a light at the end of a radial circuit be overloading it? I have a number of doubel sockets in the room already.
- If i was to take power from behind the socket, is it ok to use 1.5m cable which would run to the switch then onto the light? this would leave me with 2.5 and 1.5 all connected in to the back of a wall socket?
- when the 1.5 cable goes into the wall switch should live go to common and neutral go to the one 1way or 2 way port?
ive tried this set up before ive chased all the walls out to hide the wiring, the light worked before I added the switch into the circuit. When I added the switch it kept tripping my consumer unit out so I thought id ask for a few wise words before I blew myself up and my house.
( i know i should really consult a professional )
Thanks for any replies.
Dude diy
Dude diy
