What type of cable should be run for the following:
I have 10mm SWA from main CU in house to CU in Shed and again SWA from shed underground to decking where there is a conversion box. What cable should be run from the conversion box (attached to the deck) to the socket outlet (also attached to the deck directly next to the cnversion box)? I was going to use arctic flex but what should be used.
Max 20amps
Max 20amps
