Hallo everyone. Thanks in advance for any help you can give
Firstly I know this is Part P relevant work. Yes I am going to get it inspected
My old built in single oven has broken and I am replacing it with a new Neff single oven. The old one plugged into a 13 amp plug. The new one needs to be permanently wired because it is rated at 3.8 kw.
The queries I have are as follows:
1) There is some disconnected 6mm cable run from my consumer unit that terminates about 2 metres from the oven . This was a supply to a cooker that used to be there. Can I reconnect this, if so what size cable and junction box should I Use. I know I will need a suitable MCB at the consumer unit
2) Does it need a cooker control unit and termination box given that it is a built in oven not a removable cooker.
3) Should I use heat resistant cable or will ordinary PVC do for the connection to the oven
3) If I have to rewire to the consumer unit do I need to use 6mm or can I use ordinary ring main cable. It's rated at 3.8kw and the distance is about 12 metres max
4) I am thinking of adding an electric hob (7kw). Does this need it's own run to the consumer unit or can I run it from the 6mm. I assume not
