oven trips fuseboard
21 Sep 2008
West Midlands
Hope somebody might be able to help,moved into a new house with a hotpoint bs41 oven the grill inside the oven works fine,but the oven trips the fuseboard after a minute or two,any suggestions.
oven element knacked ,easy to replace and cheap about a tenner on ebay
open oven door, remove trays, 4 screws 1 in each corner at the back. remove glass bulb cover ,remove rear panel element in front of you ,1 nut/screw holding it in ,remove element 2 wires attatched be very carefull do not lose the 2 wires down the back of cooker hold wires as you pull off and put onto new element,job done  8)
