Why is SWA used so extensively in commercial applications, where t+e would be sufficient?
For example, we have 3 air con compressors outside at our shop. The supply for these is 3 separate SWA cables running from the main DB through 3 isolators inside, then out to the units. Most of the run is inside, above a false ceiling, and inside trunking (the armour is terminated on the metal trunking, which runs beside the DB) I would call this run pretty well protected, and dont see why SWA is required, apart from between the isolators and the compressors outside, especially for 3 long runs of the stuff.
Linking 2 distribution boards together: a loop of chunky SWA is used underneath them. They are right next to each other! Wouldn't a conduit and single cores / meter tails be more appropriate?
Linking a compressor to its remote dairy chiller: All the current it carries is for 6 fluorescent lamps and a few fans and thermostats (supply actually comes from a metaclad wylex re-wireable fuse box). Why is SWA used here?
All this seems like money wasting exersizes to bump up the cost to the commercial client: because they can afford it.
