So... I have decided to attempt overboarding a few of the ceilings in my house.
I will start from the smallest one and see if I can actually manage it and then move to the larger ones if I consider it feasible.
The joists are spaced 40cm and the ceilings are artexed. I don't know if they contain asbestos or not. To be on the safe side, I will use the necessary PPE and try to be as clean as possible.
My questions are: is it best to use 9.5mm boards or 12.5mm?
As far as I understood 12.5 is generally better, however, I am a bit concerned about the added weight, especially for the room on the second floor as the weight would be on the joists that support the roof. After reboarding, the plan is to just tape and jointing rather than plastering.
Ceiling sizes are:
-2.66 x 2.66m: 7.1 sqm (I'd be starting from this one)
-3.70m x 3.20m: 11.7sqm
-3.20m x 4.25m: 13.5 sqm second floor... this is the one that concerns me the most
Am I overthinking this?
Ceiling sizes are:
