Do you mean the tank continued to overflow ,even after turning off the water supply to the tank ??Hi
I have a water tank or two in the loft and one was leaking the other day, stopped by turning on the water. Today is ****ing out.
What’s the problem here??
No. It’s just the overflow leaking out the back of the house. ivv v e changed the stop cock so let’s see.Do you mean the tank continued to overflow ,even after turning off the water supply to the tank ??
Could have disturbed something, could just be something in the orifice seating.No. It’s just the overflow leaking out the back of the house. ivv v e changed the stop cock so let’s see.
thanks for prompt replies
The thing I replaced. See link. Stop cock?
Will get up in the loft tomorrow or the weekend.post a photo looking into this overflowing tank please. other pics showing all the pipes connected to it, and the one hanging over the tank.
use a piece of string to tie up the ball float, which should prevent water entering through the valve. Run the tap that you said prevented the overflow, for a couple of minutes.
go and take another pic of the inside of the tank, showing the water level. Is there any sign of water entering it?
Wait ten minutes. Photograph the inside again. Has the water level changed?
Take another showing both the tanks, and indicating which is higher.
What colour is your hot-water cylinder?
Which water? Hot or cold, or both?Well I’m now getting vibrations when initially turning on the water. ideas?
