as per previous post i am installing (yes i am getting se to do calcs and bc to look at it) rsj
probably 7"x4" (4.2mm max deflection)
although i may go for 2 7"x4" for even greater strength and stability
question is the padstones. one end is my outside wall (solid 2 brick total 9") other is single brick internal (4.5")
did i read someone say there is a minimum size on padstones ?
any info would be helpful as i want to run through a few possiblilties with the se when he calls.
also do the ends of the rsj need to be tied to the brickwork somehow to stop movement?
many thanks r
many thanks r
