Since gloss paint had the amount of VOC's reduced to 'help the environment' i have found that gloss paint yellows far too quickly (even in non smoking households). I have recently had an extension added and decided to stain the wood work rather that white gloss it because of this. The extension makes one room in my home into a much larger room and the rad in this existing room needed painting. I am not keen on radiator paint as its water based and doesnt give as good a finish as oil based paints.
After chatting to my local decorating centre i decided to go with 'Dacrylate Implamel vehicle, machinery and plant finishes white' paint. It is not more expensive that Gloss, is oil based but it cant be thinned down with normal paint thinners. It says on the tin 'thinners if required R1 brushing R70 spraying'. This paint smells different to gloss paint but does give a lovely smooth finish
My question is, when i decorate other rooms in my home, can i use this paint on the woodwork?
